Can I somehow view a failed call attempt that I made?
Nickddt
I tried to make the call but there was some problems with the sim and the call was not made,I didn't pay attention cause I thought it will save the call,but it didn't it was an important number from a person can I somehow view all the commands of my phone or try something to find the number?
Are you rooted . and may I say if the sims card is old just try to replace it the sims card is your ticket to reach positive data from the carrier or roaming carrier update the card to keep a good signal
I think I am rooted and I use a custom rom,so you are saying that I can acess sim card history cause I don't understand you correctly
No that's the thing I never seen it happen rooted or unrooted . I know if you call the carrier they can help. Or just use a app to monitor all call activities . in call or out call and those missed calls
If the call didn't go through, I don't think there would anything to log. Sounds like you should've tried to save the number instead of calling it first.
Can you guys recommend an app like that?
Not without a key logger or total action logger like alogcat might.
Failed call should still show. If it dosent show in the normal log. Then basicly as far as your phone is concerned, it didnt happen.
Their is no way to recover this I am afraid.
I downloaded the alogcat but don't know how to use it any tips?
It wont matter.
It hast to be there before whatever you do that you want to see the log for.
Short awnser, unless you can time travel you are out of luck
I was giving you options to save you from this happining again.
Idk if alogcat logs individual button presses, and even if so, it is probably just screen position.
Its more for device diagnosis.
Just toughts I was having.
The failed call basically left the phone with nothing to log so there is nothing that can recover it. As prepaid said, if you had some sort of key logger installed, that might have done it, but without one..
It never happened.
The phone can only log things that were successfully completed.
