Hi are there any way to start a car via mobile phone using OBD II ?
My car is Outlander GT 2016 also known as ASX GT
Thanks for helping![]()
OBDII is strictly a protocol for reading data from the vehicle ECU, nothing more.
The only way to do what you want is with an OEM or aftermarket remote start system that has a dedicated app that works with it.
IIRC, the answer is no, simply because when I plug in my OBDII reader it does not even power up until the key is turned on.
