Root Can I use zvd custom roms im on zve?
Hmmmmmm that answer is no . The reason for this is zvd has a different baseband than the zve . So in other words zve is a lot better than zvd . Also some of the modules are different . This is the reason you cant flash a zvd rom on zve . But now if u want to flash a custom rom like cm9-or 10 yes you can
you can use roms from zvd.. just need to add some files from the update but itll work.. number two is still zvd based.. just ported to zve by adding neccessary files ;)
though its not fully recomended.. but untill there are major issues with #2 than we should be ok lol
