Can i .......?
D
Deleted User
Guest
heyy :)
i have HTC Sense on my desire and i love the Clock and weather widget with the full screen weather.
i have recently been playing around with launcher pro plus. I like the way it can be landscape. and the scroll bar, but most importantly the 3D app drawer.
so my question is, is it possible to have the launcher pro with the HTC clock and the toggle switches,
or
have launcher pro and then have a gadget thats roughly the same? then if its possible to get wifi, bluetooth, gps, snyc,profile ect toggle switches and just use launcher pro?
Thanks
Ben
heyy :)
or
Thanks
Ben
There's a weather widget called Fancy Widget. Looks exactly the same minus the animations.
That might work for you.
Switchpro or Extended Controls are good for the toggle switches. There is a Sense clock clone in Beautiful Widgets I think, and if you buy LauncherPro plus you can have lots of sense-like widgets if you desire.
