I've found instructions for rooting the Exhibitbbut they don't say which model. And I know there's a couple models. Is model SGH-T599N rootable? If so, can you point me to the correct instructions for this model?
Any Android phone can be rooted if you do it manually. (Search root android adb) If you're asking about an already-written script for that particular phone, I can't help you.
extract file then enable debugging on your phone download super user or super SU nd root check on your phone Then connect your phone to usb then run impactor.exe make sure your phone is unlocked then click start nd your phone should say payout or payload a few times then run root check on your phone nd you should have easy root make sure wen you run impactor it says # drop SuperSU su to /system/xbin/su before pressing start
