Help can not delete some files on microsd
InGearX
when I am trying to delete *some* files (movies..) on my galaxy Tab S2 microSD .. I keep getting "task failed" or alike .. I have tried half a dozen file managers .. reboot .. safe mode ..
but I can delete them fine on my laptop!
I am thinking its got to be some file permissions issue ..
there has got to be some program that will let me reset all file permission on my microSD card
or some solution?
please help .. thank you ..
Have you tried using the stock system Samsung file browser, "Files" I think it's called? Because if the Tab is on Kitkat or Lollipop, third-party user installed file managers are not usually able to delete files and folders they didn't create.
Yes it's a file permissions thing, with those versions of Android. A security measure to try and stop any malware deleting or encrypting files and folders they didn't create, e.g. ransomware, which does exist on Android.
