Help Can Not Mount System
2jules123
Hello-
I am rooted on the Phantom Blazer Rom, with the FF18 Kernel. No matter what I do, I am not able to mount /System as RW. I do have SuperUser installed, as well as Busybox. All my other root apps seem to work. But..., I can't mount it. If I try in the mobile terminal after obtaining root access, I get "Read only file system". If I try in Root explorer nothing happens. It gives me a failed message if I try to change the permissions on the system folder. I had this issue on the Mijjz Rom yesterday, so I tried it on this Rom, same issue. I have also tried the "Mount /System" app in the app-store, it says it successfully mounted but the folder doesn't actually mount. I should point out, the issue started after I used a custom PIT available on xda in order to fix the emmc brick issue. Thanks for the help! :-)
