I have been trying like all get out to get off of iOS, just cant stand apple any longer...but my 1st gen ipad has yet to hit ebay after ive tried close to a dozen android tablets ... they ALL have the same problem with wifi, crappy range and regular drops. Im wondering if there is any chance software updates like ics may be able to remedy these issues or if i should stop trying and wait another year or so for android tab's that dont have these isues?
Ive tied all of the following at home:
All of these had issues with wifi...im in a 2000 sqft home, 2 levels with only 3 nearby neighbors with wifi as well...ive tried 4 routers, dlink, netgear, motorola and linksys...in every situation where the android tablets would have issues connecting, dropping off really low intermittent signals etc, my laptop and my ipad were both solid as a rock on wifi showing good signal strength. Im currently writing this on my xyboard 8.2 one foot away from my razr using hotspot and its showing 50% signal (and im in my home on the 2nd level, router is just below me in another room and it, like all the others, wont connect to it hence using the hotspot because i have to).
Ive tried every router using wifi analyzers to ensure i wasnt in the same channel as someone else, tried 2.4ghz on all channels and 5ghz on all channels, nothing seems to make a difference. Wifi analyzers show little interference other than the expected neighbor(s) wifi which again, ive tried staying off their channels.
Im about to give up and give it another year or two even though i HATE my ipad...
Comments? Suggestions? (oh, i have tried ap's as well)
Why do android tabs suck so bad on wifi? One more thing, wifi analyzers on these tablets would often show a
decent signal strength 70dbm or so when the tablet i was scanning from couldnt connect, which is one of the reasons im thinking *maybe* a later software "breakthrough" might fix these issues.
TF 101
TF 201 (tried THREE- really wanted to keep this one)
Galaxy 8.9
Galaxy 10.1
Kindle Fire (have a few friends with them)
Motorola Zoom
Motorola Xyboard 8.2 (first one i received had issues with google account, so tried two of these)
Motorola Xyboard 10.1
Theres another im not remembering the name of
