The instructions seem simple:
from :http://forum.xda-developers.com/showthread.php?t=1870926
*Make sure you are on gingerbread bootloaders before flashing this rom
HOW TO INSTALL 1. Factory Data reset 2. Wipe Dalvik 3. Format System 4. Install Zip from Sdcard 5. Boot up 6.Install GApps 7. Enter google info
(May have to remove external sdcard if coming from gingerbread)
(Do not flash gapps for ics, or you will lose your camera)
But I cannot even get to the first step!
My phone is on 2.3.5 factory gingerbread from keis update. So I am going to assume those are the GB bootloaders. Is that correct? or are they a custom GB bootloader?
Factory wipe is no problem.
Dalvik /format- I cannot find Dalvik option anywhere. Same for format, other than sd card?
Any help is appreciated.
