Help Can someone help me out with the "Top Contacts" widget please??
stevep94
I'm having a bit of an issue using the "Top Contacts" widget that comes on the Xperia handsets and wondered if anyone could help??
Basically, 2 days ago I was happily using it as a shortcut to my favourite contacts on my home screen but since then I've done a factory reset due to some issues I have had since the Jelly Bean update.
The problem now is that I cant seem to "access" the widget to manage the contacts contained within because the little settings icon that used to be sat at the top right of the widget has vanished!?!?!?
It's not listed in my app drawer and the only other place I can even see it listed is in the manage apps menu within the device menu - and even then I have to scroll to the right and view "All" and all it lets me do is clear data - which make no difference as it just loads back up with the same contacts showing!
In addition, I can't see it listed at all as an available widget if I'm using the Nova launcher and I'm 100% certain it was working in that launcher before the factory reset!?!?! :confused:
Can anyone tell me if their widget a) has the settings button still and b) can you use it with another launcher???
Thanks for any help guys...
