When I first installed Vlingo it would not read any incoming texts. I was using handcent txt. I couldn't figure out why it wasn't working and was about to uninstall my Handcent because I really wanted the Vlingo function. After doing research I found the answer and it WORKED!!! For me anyway hopfully for you as well. You have to go into the "Phone" settings then to the "Voice input & output" setting. Then go into the "Voice recognizer". If you have Vlingo installed you should have at least two options. 1 is Google 2 is Vlingo. You need to select "Vlingo". Once you've done that Vlingo should start reading the incoming texts.
