Accessories Can you recommend a thin rubber skin for Droid x that can fit into car mount?
Mc1
I have a car mount, and the hard case needs to be removed. Plus I don't trust the case. It's a top/bottom format and it just doesn't feel sturdy on the snap-shut.
I'm really looking for a thin rubber type of protective skin, ideally one that I can still keep on when I place it into the car mount.
Any thoughts or suggestions? Links please :)
Thx!!
Yes they do have droid x.just released yesterday.
1.browse their gallery
2. Favorite any artwork you like
3. Choose the create your own option
4. Scroll down to the droid x under the motorola section
5. Click star t our whatever. Then a template will load and you click and drag the arty work you like over the design.
I posted mine last night. The ghost catcher design from busted tees! $15
Go to the website...don't do the browse the store option...do the create your own design...that's where the droid x is. I can't link..I'm on my x now. If you search by phone then you won't see it.have to do create your own.
