Under 'Tethering & portable hotspot' USB tethering is grayed out. I would like to know how to get this option turned on so I can transfer data from my Nexus to my Win XP computer.
The Tethering and Hotspot feature is for attaching your phone to a computer and then using the phone as an internet connection. It's not for transferring files.
Go into Settings -> Storage -> menu -> USB Computer Connection and select the connection type you want to use.
