Cannot find a ROM to work with Axesstel SP100. Please help!
mcredd
Hi,
I am a noob, and have now spent 4 days searching through the forums, and internet to try and find an answer to which ROM to use.
I am certain that I have tried all my options, to do this without posting a thread. Please consider that I am very new to this. I have listed all the info I think is neccessary. I apologise for breaking any rules as I think I am doing the right thing by posting here. Please help.
I have just purchased and rooted an axesstel SP100, which is a dual SIM/RUIM phone with one sim slot dedicated to GSM and the other dedicated to CDMA. The phone specs are as follows:
FM Radio, GPS Support, 800
There are not Roms for every device. To create a good Rom, it usually takes several people many hours to assemble and create it. The less popular a device is, the less likely it will have any Roms available for it.
Thank you, for your reply. I am aware that it is alot of work, and really do appreciate everything you guys do. I have been led to believe that various ROM's, can work, if the specs match(board, hardware, device list, etc...), I have successfully used this to flash my MTN Steppa. I however cannot find a rom or device that matches or closely resembles the Axesstel SP100. Please help if you can.
Can you please help me with the rom you used to flash your mtnt steppa..
again roms are device specific....and mcredd said:
meaning he flashed or rooted the device, but could not find a rom that will work.
in the future you might want to pick a device that has some kind of development community that supports the device.
no devs=no roms:(
