Help Cannot hear calls
jefm
Wondering if anyone has had this problem with their Maxx. I've noticed similar threads for other Droid phones but not the Maxx.
Cannot hear call, inbound or out, on the built in phone earpiece.
Call can be heard while on speakerphone or bluetooth.
The problem is sporadic on my phone. I enabled the tone on connect, you do not hear that tone either. The phone has done this for months, it's been through two updates, multiple reboots, etc. No rhyme or reason as to whether you'll hear the call or not.
This morning I had my phone deconfigured from corporate EC500 call forwarding, just to test (even though nothing is installed or configured on the phone for EC500). Someone also suggested taking out of the Otterbox, which I did. It did not work right away, but about half an hour after I can hear calls on the phone and can still hear them now.
People have said my earpiece is probably gunked or the Otter is blocking it somehow. I get what their saying but I find it hard to believe either of these conditions block all sound entirely, even the loud "DOOT" sound when hanging up.
Thanks for any help. Great phone with no other problems, if only I can hear my calls.
Thanks La Sal, we almost double posted ^^
I have the Defender. Probably overkill but I haven't broken the phone yet either.
And, following previously mentioned advice, I've had it out of the Otterbox all day and am able to make calls. I'll drag it around like that for a while and see what happens.
maybe the case is preventing the earphones plug from fully seating in socket. I don't know but thought it might be worth checking.
Hi Razrclive,
Thanks for the reply. I'm not using a plug-in fashion earpiece or headphone, it's just the plain ol' top of phone mini speaker, opposite the big ringer speaker and big camera. I also clarified my OP a little.
My husband has the defender & doesnt have that issue. I purchased the commuter for the backing (easier for those that like to slide in pockets) and didn't experience that either. I ultimately reverted back to Trident though.
Do you by chance have an auxiliary cord plugged in (like for music in the car)? I noticed mine did that & I had to either unplug or put on speaker.
awriternot,
Thanks for the reply. In my limited testing, I found the phone has the problem with or without the Defender installed. So I ruled that out for now....
This is not my condition as I have nothing plugged into nada when doing my phone call tests HOWEVER your reply drove me to fool around with the headphone jack while test calling. When not cooperating, my phone acts just like headphones are plugged in. Thanks for mentioning the headphone jack, seems unrelated but i never gave it a first thought. So maybe the jack is bad. Doh, hardware. But I plugged in speakers and really wiggled the jack, gave everything a few "tech taps" and maybe that will fix it for now.
I think I have same problem. I am 100% stock. When it happened I would reboot phone and it woulf be OK. Finally tracked mine to a bug in Blue Tooth ever since ICS. Sometime after using BT I can no longer hear calls. If I turn off BT instead of leaving it on for auto connection, I no longer have the problem.
Sure it's an ICS bug.
