cannot mount sd card huawei h866c
onerchprk
I cannot get this phone to mount its sd card. I have did a restore on it. I haved tried a 2gb 4gb and an 8gb and none will mount. When i put them in my sons phone (Same Model) they work just fine. I had him format them in his phone but still no go? Is there something im missing or an update i need?
Hello onerchprk.
What error message, if any, are you seeing, and at what point in the mount procedure?
Ok. Format the card on the PC, making sure no files or file remnants remain, then put the card back into the device and format again, then mount.
Also, some corrupted sd cards will work on some devices and not others; even the same model and make.. if this were happening to a card of mine, I'd head out and grab a class 10.
