Help Cannot Open Camera problem
Kan13
Dear All, I have problem with opening camera. It says "Cannot connect to the camera. Please make sure to close all apps that may use camera or flashlight" but closing all app does not help. First time it was possible to open camera when I was clear cash of gallery and similar app but as soon as Iclose and open camera it was the same problem again. Factory reset and rewriting firmware did not help. I have found crash log file and here below copy of log file text:
petName=K2
versionName=v1.0.0_2015081086
resolution=1080 * 1920
versionCode=1
SDK_VERSION=22
RELEASE=5.1
Globe.REQUEST_HEADER_IMSI=unknow
Globe.REQUEST_HEADER_IMEI=357468000413722
BOARD=Android
BOOTLOADER=unknown
BRAND=KINGZONE
CPU_ABI=armeabi-v7a
CPU_ABI2=armeabi
DEVICE=Android
DISPLAY=1481YF.K468A.A1.151209.L1_MP3.FDD_3M_G4B_W18_FDDB1B3B7B20_P1
FINGERPRINT=alps/full_bd6753_65u_a_l1/bd6753_65u_a_l1:5.1/LMY47D/1449641927:user/test-keys
HARDWARE=mt6735
HOST=wtl
ID=LMY47D
IS_DEBUGGABLE=true
MANUFACTURER=KINGZONE
MODEL=K2
PRODUCT=K2
RADIO=unknown
SERIAL=0123456789ABCDEF
SUPPORTED_32_BIT_ABIS=[Ljava.lang.String;@23301c3e
SUPPORTED_64_BIT_ABIS=[Ljava.lang.String;@3a0b1a9f
SUPPORTED_ABIS=[Ljava.lang.String;@ed0f7ec
TAG=Build
TAGS=test-keys
TIME=1449642091000
TYPE=user
UNKNOWN=unknown
USER=wtl
crashTime=2016-08-16_18-45-51
STACK_TRACE=java.lang.RuntimeException: Unable to destroy activity {com.android.launcher5.bird/com.android.launcher5.Launcher}: java.lang.NullPointerException: Attempt to invoke virtual method 'boolean android.os.HandlerThread.quit()' on a null object reference
at android.app.ActivityThread.performDestroyActivity(ActivityThread.java:3975)
at android.app.ActivityThread.handleDestroyActivity(ActivityThread.java:3993)
at android.app.ActivityThread.handleRelaunchActivity(ActivityThread.java:4193)
at android.app.ActivityThread.access$900(ActivityThread.java:178)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1476)
at android.os.Handler.dispatchMessage(Handler.java:111)
at android.os.Looper.loop(Looper.java:194)
at android.app.ActivityThread.main(ActivityThread.java:5637)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:959)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:754)
Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'boolean android.os.HandlerThread.quit()' on a null object reference
at com.android.launcher5.Launcher.onLQDestroy(Launcher.java:3071)
at com.android.launcher5.Launcher.onDestroy(Launcher.java:3007)
at android.app.Activity.performDestroy(Activity.java:6292)
at android.app.Instrumentation.callActivityOnDestroy(Instrumentation.java:1148)
at android.app.ActivityThread.performDestroyActivity(ActivityThread.java:3962)
... 11 more
Please help. I just need to know if it is software or hardware problem.
Thank you.
