Cannot Surf Web
i have wondermedia wm8650 netbook... i can connec to internet via wifi and ethernet, but i can't browse internet, check mail, etc...
please advise!
gabby
Hello and welcome aboard. Thanks for joining us here. ツ
I would assume this is an internet connection problem. Have you try rebooting the router and /or unplug it for a minute or two? This type of problem isn't one of the easiest to find a solution.
I hope someone with more knowledge of your device will chime in to assist you. Here is a link to the http://androidforums.com/wondermedia-wm8650/.
Best of luck.
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
