Apps can't able to add textview to linearlayout
Hi,I'm creating viewpager app. I don't know why my textview is not added to linearlayout. I've the same source code which is downloaded from internet and I created same as the source code but my app unfortunately force stopped automatically. See my comments then you could understand what I'm trying to say...
Code:
  //adding bottom dots
        addBottomDots(0);
        changeStatusBarColor();
      private void addBottomDots(int currentPage){
        dots = new TextView[layouts.length];
        int[] colorsActive = getResources().getIntArray(R.array.array_dot_active);
        int[] colorsInActive = getResources().getIntArray(R.array.array_dot_inactive);      //upto here it works fine
        dotsLayout.removeAllViews();
        Log.d("removeallviews executed","success");
        //below code set circle in page with dark colors
        for (int i=0; i<dots.length;i++){
            dots = new TextView(this);
            dots.setText(Html.fromHtml("&#8226;"));
            dots.setTextSize(35);
            dots.setTextColor(colorsInActive[currentPage]);
            dotsLayout.addView(dots);
        if (dots.length >0){
            dots[currentPage].setTextColor(colorsActive[currentPage]);
Above code execute successfully upto **colorsInActive** if I comment the **dotsLayout.removeAllViews()** then it'll execute upto **dots.setTextColor(colorsInActive[currentPage]);** and it stopped working when **dotsLayout.addView(dots);** method executed
Code:
        addBottomDots(0);
      // dotsLayout.removeAllViews();
      //  Log.d("removeallviews executed","success");
            dots.setTextColor(colorsInActive[currentPage]);       //upto here it works fine
XML Layout
Code:
    <?xml version="1.0" encoding="utf-8"?>
      <RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
      xmlns:tools="http://schemas.android.com/tools"
      android:layout_height="match_parent"
      tools:showIn="@layout/activity_main">
    <android.support.v4.view.ViewPager
        android:id="@+id/viewpagerid"/>
    <LinearLayout
        android:id="@+id/dotslayout"
        android:layout_height="@dimen/dots_height"
        android:layout_alignParentBottom="true"
        android:layout_marginBottom="@dimen/dots_margin_botton"
        android:gravity="center"
        android:eek:rientation="horizontal">
    </LinearLayout>
    <view
        android:layout_height="1dp"
        android:alpha=".5"
        android:layout_above="@id/dotslayout"
        android:background="@android:color/white"/>
    <Button
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:layout_alignParentRight="true"
        android:id="@+id/buttonNextid"
        android:background="[USER=84939]@Null[/USER]"
        android:text="[USER=696546]@String[/USER]/next"
        android:textColor="@android:color/white" />
    <Button
        android:layout_alignParentLeft="true"
        android:id="@+id/buttonSkipid"
        android:text="[USER=696546]@String[/USER]/skip"
</RelativeLayout>
Please help me.Thanks in advance :)
Still not formatted correctly. Take out all the extra line spaces, and indent it properly.
Also you need to include a stack trace from the Logcat output if your application crashed unexpectedly.
