Help Can't add notification sound on MotoG7 phone
hmw3
My MotoG7 phone runs Android 10. I want to add a longer notification sound than the choices provided. So I created a short .mp3 file, and downloaded it to my phone. When I click on 'Add Notification' my MP3 file pops right up. I select it. But nothing happens. I don't see any other step to take at this point.
I have tried the same procedure to try and add it to the ringtone. Just like for the notification sound, I get to the same point, but nothing happens.
I have spent hours searching on the internet, but have not been able to find anything that addresses this problem. I have tried some of the procedures mentioned for various versions of Android, but they don't work either.
Have I missed an obvious step somewhere, or is this a known problem?
Also, is there a way to change this purple background to white? It is hard for me to read what I write.
Harry
It seems that you need to custom your ringtone as well as the theme. Maybe you can post some screenshots about your steps. Someone might be able to find a clue for you.
