Help Can't add widget to bottom two rows of home screen 1
Can't add widget to bottom two rows of home screen 1.
- Sony Erricson Xperia x10
- version 2.3.3 Gingerbread
Thanks for any help.
Do you already have an "invisible" widget there? It does happen sometimes. Try pressing the spot and see if it highlights as if there were a widget in that spot - if so, drag it to the trash can.
Hi Wayrad, thanks for the tip but "no" that does not resolve the issue. I long tapped on all 8 cells that are occupied and every time the "Add to home screen" menu came up.
Go to settings>applications>manage applications>all - then look for Sony Ericsson home (icon is a white house with blue window) and clear data.....this will return your homescreen to as it was out of the box, but should solve your problem.
