Can't boot nook without clock work recovery
Tychonose
Is it possible I could have done my Nook permanent damage? I rooted my nook and had access to the market but I wanted my nook to be faster and look more like My HTC evo. So I took a phiremodv4-1 and used win32diskimager and burnt it onto my SD. So I fired it up and it got stuck on the nook color screen with the green robot just staring at me. This is how I came across CWR I ran it, and ran the wipe to return it to factory settings. Then when I rebooted much to my delight I was met by a bee instead of the android. I was very impressed to say the least I spent a few hours configuring it. Then decided it was so awesome that I needed to back up the rom. Then I went in to unmount my SD card so I could use it for storage. There wasn't an option to unmount so I erased the card and powered it down. I haven't been able to make it come on again without using clockwork recovery. I take and I format the system, format data, flash the SD zip. If I pull the card it will never reboot, If I leave the card in it boots to CWR. Is there something else going on I follow the uTube and tutorials very closely. I mirror their steps exactly yet yeild no results. I have the android SDK and I can't get my device manager to take the drivers. How does the device manager know it's a nook color. Seems like if it knows so much about the device it ought to be able to eat the driver when I point it straight at it.
