I'm currently trying to install xrecovery to install android 2.3 but when I try to change the permissions of the program in Root Explorer I get this error.
'Permissions change was not successful. Please note that some file systems(e.g SD Card) do not allow permission changes.'
I have my phone rooted with superuser aswell
Anyone help??
oohhh yeah as soon as i solve my proble because of lack of gauidness quickly i register to help you buddy :
mine had same problem and this is solution
unistall all xrecovery u installed before
delete previous xrecovery.tar and other 2 file (busy box) and others from root and system\bin directory .
1 download recovery signed apk (mine downloaded from mediafire)
site wont let me put link here . u can easily search "recovery signed apk mediafire" on google and find it
2 .go to market and install busy box .
2.1 -when it ask what version u want to install choose th last one 1.8...
2.2 -and when it aks where do u wanna install , choose system\bin
2.3 -done installation
4 now install xrecovery_singed.apk
when u wanna istall it 3 items shows bellow the installation buttom .
choose install and u will see three item checked(means installed)
5 .. now use root explorer and go system\bin
6 find xrecovery.tar and change permission
if u had problem let me know
