Thiefwannabe
Hey guys,
I just rooted my Optimus V last weeks, and I'm currently using CyanogenMod BACKside-IHO (and I freaking love it!). Everything's been going fine, better performance/battery life/etc., but I just found out I can't connect to the WiFi at either my house or my school. It tries to obtain an IP address for a minute or so, then times out and starts the whole process over again.
I've also discovered that whenever I try to use WiFi Tether of Wireless Tether, both say there's an error and to check 'Show Log', yet the file doesn't exist, getting me nowhere.
I'm for-sure rooted, 3G works, pretty sure I installed the ROM correctly (since nothing else is messing up). Not sure if I'm missing/have the wrong kernel, radios, etc., or if the routers just can't/won't accept my phone, so I was wondering if you guys had any idea what might be going wrong.
I'm sure that this is a problem that has already been solved and there's a thread addressing it, but I've scoured the forum and haven't been able to find anything that helps me. So, any help that you guys could give would be much appreciated!!!
Thanks!!!
Thanks!!!
