Hi
Once i have applied the fingerprint my phone asks every wake up for the 4 digit code!
I have disabled trhe fingerprint and it comes up again every wake up!
the option to disable it is greyed out!
Go to settings --> advanced settings --> security scroll here down until you see the option to clear certificates after you did that you can change screen lock or turn it off.
