cant enter recovery mode
  • Start date Start date
A
Android Question
Guest
i rooted a friend of mine samsung duos s7562 it worked fine. Due to the low RAM it has i disable some of the samsung apps from starting with the phone to save RAM for more useful apps. But after i did so and rebooted the phone I'm now stuck samsung logo screen, where it will just go into a reboot loop or simply just power off after an attempt to boot.
When i press the power+vol up+home key the phone wont power up at all and wont come on unless i resit the batter, if i press power+vol dwn+home key then the back light comes on for a few seconds then goes off
How can i fix this issue?
Sincerely,
Friend in need
