Can't flash Unlock_code.bin
These are the screen shots
not sure if it makes a difference or not, but directions here says to put it in a separate folder called "unlock-bl"
once you get the token code close the command window. then reopen the command window making sure that it is for the "unlock-bl" folder and then enter
Code:
fastboot flash unlocktoken Unlock_code.bin
