Help Can't get GPS location fix
Lauris
Some weeks ago Waze started acting up and not finding GPS location.
Then it randomly bounced between on and off, and now I can't get it at all.
GPS test says NO FIX, with 16 satellites in view and 3 in use (though they vary a bit).
Would this be due to a malfunctioning GPS receiver? If so, is it possible to replace it?
You must have your settings in gps rather than the hi accuracy set, don't you?
Some times when the just gps is set..barely can't find it self..it harkens to me all the time..even after driving for 10 minutes..
