Can't get hotspot to work
axel_2078
I went into the hotspot settings earlier and changed the wireless AP name since it was really long and now when I try to turn the hotspot, it fails after a few seconds and says "Checking subscription status" and then says "Data connection not available". I don't get it. I got it to turn on once before I changed the AP name. Why won't it work now?
Probably because that "long name" is authorized on your account. Call your carrier's tech support.
Yep, that's exactly right. As soon as I changed the name, my phone was dropped off the network. I called tech support and he had me change the APN to something else and it started working again. The lesson here is, don't change the default APN!
