Helpppp when I to make a phone call, I cannot hear anything but the phone rings as normal at the other end for the person I called. I cannot hear them they cannot hear me. I get a bleep like the phone has disconnected but the call still shows connected
When I hang up the signal meter changes from 4 bars to a circle with the bar through then if i try to immediately use the phone again I get a "not registered on network" message.
sometimes it will return to normal in a minute or two and I can make a call sometimes its days before it returns to normal.
I asked a local phone shop to look at it and they did the following:
Changed the ariel
Rooted the bloody phone (without my permission)
Reinstalled sofftware
tried a new motherboard
All without success
Im at the end of my tether sometimes its fine for a week then boom .
It makes no difference whether I reset (turn on and off), hard reset (take battery out when its on) the shop also tried a factory reset.
Is there something i,m missing ??
Yes the sound is on. obviously I cant contact Samsung because the idiot repair shop rooted my phone , I only wanted them to check the settings to make sure it wasnt something simple.
Changed the ariel
All without success
