Root Can't mount internal sd card and external sd card at same time
JayDogg
Ok I'm going to give the long short story, I was on CleanRom Pro, rooted, AmonRa with S-off. About a week ago I installed an app that need root and for some reason root would not work. Then I noticed that no new app that needed root would work only apps that already had root access would work. I uninstalled root and reinstalled but that just made it worst now no apps could use root. I then rolled back to a backup I had made about two weeks using AmonRa. Now same problem I had before with only apps that had root access already would work. So I went to flash a clean install of CleanRom Pro only to find that after I used the AmonRa to roll my phone my bootloader was locked and I could not get back to AmonRa recovery. Next I unlocked my bootloader and flashed jb_boot to be on the most current firmware and radio. But here is the kicker when I rebooted my phone it only saw my internal sd card as 12kb. I tried a few fixes which I couldn't get to work so I flashed the most current stock RUU. So now I have a stock phone Android version 4.0.3, HTC Sense Version 3.6, Software 4.03.605.210RD. Here is the kicker my internal sd card only show up if I don't have my external sd card in, so if I put in my external sd card and boot up the phone it doesnt see either internal or external and if I plugin my usb cable my only option is charge. If I take out my external sd card I have 10.4 gigs HTC STORAGE which I can see in file expert and if I plugin my usb cable and mount the disk drive. I have since flash AmonRa recovery and rooted the phone. There are all of the stats of the phone as it sits
Software Number 4.03.605.210RD
Kernel version 3.0.16-g408e1bo, htc-kernal@u18000-build-144#1
Base Band verison 2.22.10.0801r, 22.10.0803r
Build number 4.03.605.2 cl436457 release-key
In Bootloader
Vigor PTV Ship S-off rl
HBOOT-2.27.0000
Radio 2.22.10.0801r, 22.10.0803r
OpenDSP-v14.6.0.7709.00.0507
I would really like to get my internal sd card and external sd card working again so any and all help would be great. If anyone need an more information I will gladly provide it.
Thanks Jay
Thanks
EDIT / DELETE
REPLY
http://forum.xda-developers.com/newreply.php?do=newreply&p=41246151
In Bootloader
HBOOT-2.27.0000
Thanks Jay
Thanks
EDIT / DELETE
REPLY
In Bootloader
HBOOT-2.27.0000
Thanks Jay
sounds like youre maybe having an sd card issue. have you tried a different one?
also,if youre 100% stock at the moment,chose the "clear storage" option from hboot.
Thanks for the reply, I tried two other micro sd cards and same thing. One was even brand new and when I stuck my card into my girlfriends phone it worked just fine. Any how I reformatted my micro sd card again and reformatted the internal card and reflashed the most current stock RUU. Looks like everything is working again now I see both the internal and external sd cards when I boot up my phone. Then I was able to flash my rom and all is good. Thanks for the help.
