Root Can't read PDF's ???
albert_htc
Cyanogen mod 7.
For some reason I don't seem to be able to open or view any pdf files.
Any idea how I get them working again.
Rebooting hasn't helped.
Thanks
get a pdf reader from the market, think i had the same problem with cm7, not all roms come with a pdf reader, but easily solved, Adobe is free i believe, or if you have been using cm7 and reading them try a different reader, there's quite a few
I tried pmac's solution with mine but that didn't do a thing. My HTC Sensation wouldn't let me view any PDF's, so I downloaded a new browser, Opera Browser!!! And now I can read all PDF, or just view them. (I tried Dolphin Browser, but that doesn't work)
Hope that helps
Adobe works fine for aosp roms. If the sensation Rom was HTC sense, then it should handle the files without the need for any additional reader.
For Dolphin, you need to download an add on from the play store.
However, looking at the dates of the OP, I would hope he has managed to solve this by now!
