cant remount system as R/W Huawei y6
so guys i really need someone help because i cant try nothing.. i have got a huawey y6 rooted and i need to remount system to r/w but now is r/o i have try everything.. adb shell from my ubuntu.. command ( su ) from the terminal emulato all the app for remount system but nothing.. everytime the same error code.. this is read only.. if someone can help me thanks :)
Welcome to our AndroidForums, @darknight216 :).
Can you tell us exactly what mount command you are using to try to remount /system in read-write mode and also include the output of a simple "mount" command, too?
Thanks!
Good as place as any to ask this. I have seen this symbol in command lines. What does it mean? I can't find it anywhere on my keyboard.:)
That's the vertical bar or pipe command/operation (see/try shift of the "\" character/key).
It's used to pipe / redirect the output from one command to another.
This is my output for grep /system..
u0_a188@hwSCL-Q:/ $ mount | grep /system
/dev/block/bootdevice/by-name/system /system ext4 ro,seclabel,relatime,data=ordered 0 0
And if I do a simple mount it mean this is read only system
I'm thinking there might be some sort of write protection employed here. However on an HTC device, it will mount r/w until reboot at least. Try maybe Kernel Aduitor to set SELinux to permissive. Probably a command for that though.
Okay, let's try this sequence then:
# mount | grep system
# mount -o remount,rw -t ext4 /dev/block/bootdevice/by-name/system /system
Hopefully, this version of the mount command will work vs. the generic ones you saw and tried before and that the second "mount | grep system" will show "rw" instead of "ro".
u0_a188@hwSCL-Q:/ $ mount | grep system
-t ext4 /dev/block/bootdevice/by-name/system /system <
mount: Operation not permitted
255|u0_a188@hwSCL-Q:/ $
I dont know if I copy all right but I m sure in the command console was right but it say operation not permitted
Hmm, I can't tell from the above, but you did type (or paste) this command on a line all by itself?
Also, I don't see that you su'd to root since your prompt is still a "$". I.e., normally, you'd do this first:
$ su
Notice how the prompt changes from "$" to a "#"?
Are you sure you're rooted?
Yes I m sure I m rooted because all my app that need root work and my root checker is working
