Help Cant root and malware! help please!
Yeah just relised i never put in the nj2 file to flash sorry for all the trouble btw thanks for really answering my questions
the nj2 files taking a lil while to download
You said earlier that you were pretty sure you were on 4.4.2, did you go to Settings - About Phone and check the build and baseband version?
Check in Settings -About phone to make sure your build and baseband match, both NJ2.
Also check to see if you IMEI info is intact and not null.
Hi i have recently downloaded a bad apk file virus/malware of completely glitchy app
This app has made it so i can't uninstall it because it is in the system apps file so I need root
it has been replicating itself and pretending to be com.system.ui and installing other apps such as panel app Swype Kika emoji keyboard and solitaire
So I decided to root to see if I can delete this malware I have rooted a device before and I got my self cwm
and everything was working out great after I disabled my antivirus on computer I didn't get any errors saying root lost or anything so I go ahead reboot the system but i have no root just the recovery right now I'm stuck and have nowhere to go supersu won't even work root checker says I don't have root.
If anyone's wondering i seem to have two malware files called com.swiping.whale.apk
com.system.cap.hm.aupdater.apk
These files were scanned using Malware bytes as this was the only app that saw the malware
I got this after i downloaded this file on this website: **mod removed pirated site link**
This is what i get for cracking i guess.
I also tried a whole bunch of mods such as cwm and twrp and others
I have tried doing a reset won't work files are regenerated after rest
Also i am new to Andriod forums so if post this in the wrong section sorry.
Any help much appreciated
maybe in some Advanced Mobile Security and Antivirus from Google Play Store it's free and run a device check a
Maybe install Avast Mobile Security and Antivirus from Google Play Store and then run a device scan. Let it scan deep inside your files, there's an option for this in settings, and it will give you recommendations on how to remove the infected file. Hope this helps!
