A
Android Question
Guest
For a couple weeks, sending mail from xoom-fe or samsung tablets, get a message "connection problem" and it fails. Also what is "master sync"? It's turned off and I can't find it in help.
Is this on Kit-Kat ROMs? It looks like you just need to turn on sync. You should be able to find it under the system's settings. It may also be on a notification widget or through quick settings.
