HI All
I can't send pic messages so contacted o2 who sent me this email with the settings to enter manually. I have done so but when the message arrives to another phone it says data not sent.
Thank you for your recent handset enquiry regarding handset settings. Please find your settings details below.
GPRS WAP & MMS
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering O2 into the settings that the letter O is selected and not a zero.
When entering the following information do not press Save until told to in the instructions.
GPRS WAP & MMS
- Press the Menu key
- Tap Settings
- Tap Wireless & networks
- Tap Mobile networks
- Tap Access Point Names
- Tap New APN
- Tap Name then tap the text box and enter O2 Pay Monthly MMS then tap OK
- Tap APN thentap the text box and enter wap.o2.co.uk then tap OK
- Tap Proxy then tap the text box and enter 193.113.200.195 then tap OK
- Tap Port then tap the text box and enter 8080 then tap OK
- Tap Username then tap the text box and enter o2wap then tap OK
- Tap Password then tap the text box and enter password then tap OK
- Skip past Server as this is preset as Not set
- Tap MMSC then tap the text box and enter http://mmsc.mms.o2.co.uk:8002 then tap OK
- Tap MMS proxy then tap the text box and enter 193.113.200.195 then tap OK
- Tap MMS port then tap the text box and enter 8080 then tap OK
- Tap MCC then tap the text box and enter 234 then tap OK
- Tap MNC then tap the text box and enter 10 then tap OK
- Tap Save
- Tap your new account so a green dot appears next to it
- Press the Back key four times to return to the standby screen.
