Help Can't upload pictures and app problems
ChloeFox
So I'm using a WileyFox Swift which just updated the other day to Cyanogen OS 13 (13.0-ZNH0EAS2NH) , so Android Marshmallow 6.0.1, and I've came across a lot of problems. My main one was that before I updated, I used an SD card on my phone, and moved all my apps to that. Now that I've updated, I had to wipe my memory card in order to use it as internal storage, but i put the files back on it. All my apps were gone, which wasn't exactly a problem, I just redownloaded them. But I had a lot of problems with apps crashing when I tried to open them. One app in particular is one I use regularly called Peach, and everytime I quit peach it logs me out, which it didn't do before the update, or on any of my other devices.
I've also found that when I try to post pictures from my device to peach, I get the error
-2: 60012a1b-28ea-4f11-934a-9638950e39fe: open failed: EROFS (Read-only file system)
Also (sorry if it's too many problems in one post), after I've used the device in landscape mode and it goes back to portrait, the notifications bar when i pull it down is magnified? I can still read it, but its almost as if it's zoomed in so that the borders are cut out.
