It's really interesting to see everyone's opinions on this. Having read many of these posts, I would probably hesitate to call this a 'HUGE design flaw' again, and would probably call it more of an annoyance.
Thanks for giving me some perspective. I think that I am so happy with the phone otherwise, that I am just looking to nitpick.
I bought a cheapie car charger at Walmart and noticed the same problem. It connects okay, but you have to push hard and then make sure to keep the phone fairly stationary to avoid losing the connection. I also consider it more of an annoyance than a design flaw.
BTW, I wasn't even aware that there was a sliding door until I read this post. I guess mine was open from the factory and I just never noticed it.
Somebody posted about this a while back and had a link to where we could get OEM cables and car chargers cheap. I think I got 2 data / charging cables and a car charger for about $15.00. Unfortunately, the car charger died somehow.
Yes, there are "OEM" ones that appear on eBay. However, they're "OEM" only in the connector... they are however much shorter than the OEM cables.
If you're looking for OEM length too, you'll pay more... or you can just get a third-party cable from Monoprice for like 1/2 to 1/3rd the price then spend 30 seconds on it with a razor blade.
Who'd you buy it from? All the vendors I've seen either explicitly mentioned it's about 3' long or if they didn't mention, admitted as much when I inquired. One said he also had the 6' version available for like $5.
i dont get this issue? people helped me on here with postings about how to fully click the door open...and re OP's problem...i dont get it? i even bought a el cheapo charger and micro usb combo from ebay for a buck..and it fits fine...must be unusual second party ones he is buying i have no issues??
The door on mine is pretty much open 24/7 anyways. I bought that same Monoprice cable and I just used a pair of wire clippers to shave it down and it works fine. However - I did buy a generic MicroUSB car charger from Best Buy and used it on a recent trip. Due to the clips (or something) it actually started chaffing the metal on the connector. Suddenly the phone screen is blinking saying "USB Connected" then disconnected, then connected, then disconnected, etc etc. I had to pop the battery on it and find something to fit in there to clean it with. I then went to a Radio Shack and bought their car charger and it worked fine.
I ordered a random cable off of Amazon which turned out to be a Blackberry branded micro usb that doesn't fit quite right. It def doesn't snap into place but it still charges it and is good enough. I also have a random car charger that I bought at Target that fits perfectly.
I know what the OP is talking about. I have 2 MicroUSB cords that work and a Motorola-branded car charger that works great. At work there are 2 chargers for some random Verizon devices that do not fit properly...very odd.
The sloping case does restrict the feasible set of cables. It will always be an annoyance. Finding the right car charger is hence a struggle too.
Sad how AT&T chose this "stylish" case, when one does no have the problem with the Captivate sister phone, VZ Fascinate, a case I prefer anyway! Who do they think preferred this case anyway?
