Car and Wallchargers
Darkwarrior006
Forgive me if this has been posted already but i couldnt find it. What car and wall chargers would yall recommend? I looked a couple on amazon but i couldnt find any that i really wanted to go with. Any suggestions?
I don't think it matters much, cables are cables. I'd get the longest and cheapest you can find, just make sure it's micro-usb and you should be good to go!
monoprice is the way to go, just make sure you check the spec's, you will want a charger that puts out more than 500milliAmps, the 1000milliAmp ones on monoprice are good.
