NPC
The AUX cable with volume worked, I just received it in the mail a few days ago. This is an extension cable, so I connected it to my existing AUX cable. Sure enough, it resolved the issue.
For good sound quality, you have to make sure to turn your Samsung device volume all the way up after you plug in the AUX cable. Then use you car volume knob for control. If I do not do this, I get static, poor sound quality, and even engine noise. So long as the Samsung and the new volume control mechanism are both turned all the way up, it sounds perfect. I may even super glue the sound control into the full volume position. It is very delicate, and brushing against the seats turns it down.
Here is a link to what I purchased:
Kalevel® Outdoor 1m 3.5mm Male to Female Stereo Headphone Audio Extension Cable Cord with Volume Control (Black)
http://www.amazon.com/gp/product/B00M5UYU18/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
While this works, it is a hack-job and super annoying, Samsung should fix this.
