Car bluetooth - Fatal Exception and other Issues
g4rvd4
Dear all,
My HTC Desire is now 15 months old, and still works as new. No, better than new since it's rooted and faster.
I got a 3000 mAh battery pack which does jut out from the body a bit, but now I can use the phone without worrying about juice. Runs for a day and a half without a problem. And I'm an extremely heavy user.
Coming to the problems:
My car has a bluetooth feature to stream music from the phone, and to take and make calls. Bluetooth music streaming works perfectly, and I can skip songs using the car controls.
I am facing the following issues with the "Phone Connect" feature when I pair the Desire:
  1. After any and every incoming or outgoing call is completed, I get a pop up on the screen which says "Fatal Exception..." and I can only force close from here. When I force close, the signal strength icon shows a cross and all connectivity is lost for sometime, including BT: car says "phone disconnected". After a while the signal strength comes back and BT can be reconnected.
    So basically I have to repeat this process everytime I make or answer a call via the car BT feature. Needless to say, it's a PITA.
    I am guessing this is a problem to do with the radio or kernel of the phone. Not sure which. I am sure the experts on this forum can guide me to a radio or kernel file which may solve this issue.
  2. My second problem has to do with the phonebook feature of the car. It can pull the contacts, the recently dialled numbers, recently received numbers, and missed calls. Only in the Desire it doesn't.
    The phonebook feature can only see the contacts in the SIM card.
    The recently dialled, received, and missed calls don't work. Numbers only show up on the car list if I have made/answered/missed a call while connected to the car BT.
    The only feature that works as it should is redial.
    As I am told, all Nokia models work perfectly on the same car model, and since we own a 'smart'phone, not to mention an Android, we should be able to get it to work however we want it to.
    Any fixes for this one?
Thanks in advance.
PS. If you want the exact error message thrown by the phone after taking/making a call, I can write it down and get back to you afterwards.
