Car Charger Recomendation
komobu
Member
Hi;
I have a Samsung Tablet (Note 10.1 2014 edition) and a Samsung Cell Phone ( Note 3) . I am a limo driver and can sit in a car for more than 5 hours at a time. I am looking for car charger recommendations. I am hoping to use the same charger for both of my devices.
This 2.1 AMP Rapid Dual Micro USB Car Charger w/ led looks kind of cool because you dont have to worry about which side of the connector is up and it even gives you a light to help when plugging it in ( http://www.ebay.com/itm/35110761681...49&var=620389580209&ssPageName=STRK:MEBIDX:IT )
I also saw this Qualcom Quick Charger but dont know if my note3 or 10.1 2014 tablet will be able to take advantage of the quick charge technology. ( http://www.ebay.com/itm/Aukey-Quick...299?pt=LH_DefaultDomain_0&hash=item1c53aee9ab )
The last one I was wondering about is the Anker 4.8a 24 watt. Again, I dont know if if my note3 or 10.1 2014 tablet will be able to take advantage of the technology. ( http://www.ebay.com/itm/Anker-4-8A-...737?pt=LH_DefaultDomain_0&hash=item3f4ce88de1 )
Does anyone have any recommendation of what charger I should get? If you have one that you are pleased with, but is not one of the three I mentioned, I would like to hear about that as well.
Thanks for any advice
To be honest, compared to those USB car charger for Androids, I prefer to or would rather to recommend this one both compatible with Androids and ios devices.
http://www.amazon.co.uk/gp/product/B00WDWPOF4/
Because under most circumstances, I use Apple devices more. I think a MFI certificated version will be the most important in case of power issues. This one provides 6.6A/33W high power supply I believe it will meet you demands in common. :D
