Accessories Car Charger
Had a RAZR before my EVO and still have the Motorolla Car Charger for it. I wanted to be sure I could use it with my EVO without causing any damage? The charger has the same Mini Usb connection the EVO has.
Would like to not have to buy a new car charger if I don't have to.
Thanks for the Help!!!
It might work. Can you find the specs on your charger and see if it says it can be used for other phones? If it works on other high end smart phones by htc, then it should be fine.
I only have the charger itself, no literature with it. Is there a website where I could see if the model# is compatible?
Model# SPN5400A
Entrada: 10.8-33Vcc Salida: 4.75-5.25Vcc
