Car Dock
I've recommended this Arkon mobile grip mount before and most people have been happy with it, might want to check it out. It has a removable sticky suction base that works well on most dashboards (even if they're textured).
Mobile Grip HTC One X Dashboard Car Mount
They have a couple other types of holders that would work just as well.
Look for Brodit when you like a dash mount car kit.
Mounts for your car model and holders for your phone model can be assembled :)
Harry
I recommend: store.tetrax.us - Tetrax Store It's a magnetic system where you put a metal button on the back of the phone and the mount either sticks to your dash, or vent. Really strong, and I've been happy with it. I have the XWay which stablizes the phone with a rubber "X".
They aren't cheap, but since all of us have bought multiple mounts in the past I thought it was worth it. You get a hand full of buttons so you can use it for which ever device you want.
