Car problem - "Connected as a media device" - possible solution
I own a Samsung Galaxy S3 (US version). I also own a 2013 Hyundai Sonata GLS (US version - with no electronics-related optional items). I like both. Both serve me well. And they seem mostly compatible with each other, but not quite 100% so.
The Sonata comes with Bluetooth standard. My S3 pairs with the car's Bluetooth without any problem. I have TuneIn Pro on my S3, and can listen to the output through my car's speakers, via Bluetooth. I can get turn-by-turn directions through my car's speakers, if I use the S3 for GPS navigation. And I can make and receive phone calls just fine, using voice commands. So all of that's great.
The Sonata has an AUX jack, a USB port, and 2 cigarette lighter sockets. Since I'd rather not run the S3 off its battery if I'm going to be using it on a long drive, I'll plug it into the USB port. And that's when I run into a problem -
Once I plug the phone into the car's USB port, "Connected as a media device" shows up as a notification. And it seems to cycle on and off several times per second. Very annoying!
If I time it just right, I can tap that notification, and go to a screen which gives me a choice between "Media Device (MTP)" and "Camera (PTP)." Even if I switch from the former to the latter, the "Connected as a media device" notification continues to cycle.
The phone still seems to work just fine, via its Bluetooth connection to the car, mind you.
Question #1: Is there some ridiculously simple way to get the phone to stop with the "Connected as a media device" notification cycling?
Question #2: Would it be reasonable to conclude that having this cycle on and off every split second might be bad, somehow, for the phone? Does it put extra strain on the CPU and cause things to run hotter and/or drain the battery faster (faster than the USB port's ability to keep the phone charged, perhaps)?
So, I turned my powerful intellect to finding a solution for this problem. Just before getting to the point where I was going to drink sapho juice and recite the Mentat's chant, an idea occurred to me - what if instead of trying to keep the S3 charged by pluging it into the car's USB port, I instead plugged it into one of the cigarette lighter sockets?
I mean, I assume it's entirely possible to charge the S3 by plugging it into a cigarette lighter socket. Heck, it might even charge better that way than it would from a USB port, since getting 1000 - 2000 mA out of a cigarette lighter socket is probably easy, whereas many USB ports presumably struggle to manage even a fraction of that.
Sure, a cigarette lighter connection is a "dumb" connection, as opposed to a USB (a "smart" connection). You can't transfer data between phone and car using a cigarette lighter socket, the way you can using a USB port. But that's perfect! All I need the connection for is to keep the phone charged. I can't see how the car could know that the device plugged into the cigarette lighter socket is an S3, much less worry about "Media device" issues.
Question #3: Do you agree? Is it likely that I could solve the problem by charging via the cigarette lighter socket, as opposed to plugging into the USB port?
Question #4: If so, is there anything I ought to look out for, in choosing a cigarette lighter adapter? I'm leaning toward buying a small, low profile, no "bells and whistles," black one, for about $4, off of eBay. Should I worry about overcharging, or shorting something out, or anything like that?
I'd appreciate some feedback on my plan (or on some even simpler way of addressing the matter).
Michael
Update - I've been told via private message that the whole "Connected as a media device" thing may be caused by - get this - the fact that I'm using the USB cable that came with the phone. At least, this other fellow who had a similar problem was able to resolve it simply by switching to another cable.
It seems absurd that this is the cause of the problem, but at least it's easy enough to test it out. I forget - does the S3 take a standard micro USB size connection? Anyway, I'll either pick one up online, or splurge and get immediate gratification by buying one at Walmart.
Michael
Michael
Did you resolve this issue. I just discovered the exact same thing today. S3 and a Hyundai.
I use the cigarette lighter socket in my 2012 Sonata and it works great. If you've got the bluetooth connection you don't need data, just power. As you say, from what I understand, you'll charge faster using the cig lighter than USB anyway.
Just a momen...
It is by will alone I set my mind in motion. It is by the juice of Sapho that thoughts acquire speed, the lips acquire stains, the stains become a warning. It is by will alone I set my mind in motion...
You and I are among the ten-twenty people that liked the movie...of course, the book was much better.
I have an '11 Optima (same car, different skin) and use a dual-port mini lighter adapter with my iPhone with no issues. In most devices, charge regulation happens in the battery (or phone) so as long as you're not plugging it directly into the mains feeding your hour house you should be fine.
Bluetooth streaming was how I did it too. Works like a charm but of course the steering wheel controls don't work then.
I would also be interested to learn if a standard USB cable will work and allow steering wheel control.​
Really? I use an adapter which plugs in to an aux port to charge, and stream all audio via bluetooth. All my steering wheel controls work. Must be a car compatibility issue? I have '12 Mazda...
Oh for God's sake, did you have to post that! Now I'm gonna have to go buy a new car! :banghead:
yeah no problems here in my 2011 Jeep Wrangler, sounds like a problem with Bluetooth in your car, maybe the manufactures has a update, I know Jeep has a few for my Bluetooth that have fixed a few issues.
Those of you using USB to charge your phones, keep in mind most cars only supply 500ma over USB and the S3 being the powerful phone it is needs 1 amp to charge and use things like Google Navigation at the same time etc.
Just plug it into the cigarette lighter and the problem with it will be solved. If you plug it into an actual USB port it will try to connect as a USB (Working as intended).
Yup. Am using the cigarette lighter and Bluetooth, and all is fine. The cigarette lighter adapter ran me $1.99 via eBay, and comes from the far off, exotic Orient.
(If anyone's wondering, I'm also using a Mountek CD slot mount for the phone. It's a clever idea, and it works great. Same applies to the app TuneIn, which is free, gives me access to thousands of radio stations and recorded programs, and which I find myself using regularly.)
Michael
I am having the same problem with 2 small differences. I have a Samsung Mega 6.3 and the problem happens at work while I have the phone charging via my work computer USB. The cycling "connected as media device" seems to be draining more power than the connection is providing.
