Help Car USB not charging Nexus
So I have a dual USB port charger in my car and it does not charge my Nexus. I have tested and the charger does charge for my ipod touch when plugged it. Could it be the 3rd party usb wire I am using? Because I had no problems charging my OG droid before. Any input would be appreciated since I need to charge my phone while at school since I heavily use my phone during my 2-3 hour breaks.
Sounds like something is wrong with either the charger or the cord indeed. Maybe the OG droid required less power so the charger worked ok? Get a car charger that outputs at 1 Amp, then your phone will charge at AC speeds.
This is a link of the usb charger I use in my car not sure if it prodduces 1amp.
image-3215015-10550783
ZAGG | Dual USB Car Charger
Amazon has them much cheaper...
Note: to check if a charger is charging at 1 amp
plug in your phone and open up the battery menu under settings
at the top if it says
Charging (USB) its charging at .5 amps
Charging (A/C) its charging at 1 amp
Not totally true. I have my GNex plugged into an OG Droid charger that runs at .85 amps and it says Charging (A/C):confused:. Maybe > .5 amps it gives the AC message as USB only charges at .5.
True, I should of qualified my answer with the limitation of the charger. If the charger doesn't output 1 amp the phone won't charge at 1 amp...
The A/C - USB indicator is a "USB SPEC" thing. to keep devices from drawing to much power, if its plugged into a USB source the device will self limit to (.5 amp)
My understanding, is the way the device tells is it checks the middle 2 pins, if there shorted it, it knows its connected to a power source that can charge at higher then .5 amps.(and shows A/C)
If you google you can find many examples of people that have "hacked" chargers that aren't wired properly.
Neat, learned something new today! :D
