'Carbon' Restoring Help
Hey Chaps, first time here. I bit the bullet yesterday and rooted my Nexus 7 first time. All went well. Just before though, I backup up my data (not Apps) with Carbon (free version). The option to backup to computer never was visible to me like it's supposed to, so I chose to backup onto device.
Now, on the Android in Internal Storage> was a "carbon" folder, it had loads of com. folders, which would each contain a .nomedia, .ab and a picture named after the folder (app com.) name, which was the icon pic. So assuming this was all the stuff I backed up, I copied the carbon folder to my Desktop. Rooted / formatted, reinstalled carbon and went ahead and placed that carbon folder back in my internal storage right where it was before. But when I run carbon on my Nexus and go to restore, the list is simply blank and doesn't recognize my carbon folder ' backups. I've checked through all the app settings to no avail. Also when I use the Desktop app, the server address it creates doesn't load anything, just a dead web page.
Please help anyone??? Is it possible to restore this data with another app or is it locked to carbon or something?
Much thanks for any help
Try deleting the copied carbon folder and running the app.. backup 1 program so it creates the folder and you should see the com. App
Replace the contents of the folder with the contents of your carbon folder.
Run the program.
