jreink01
Android Expert
I just installed this rom from stock. (A100)This rom is nice but I am having a few issues. I only have 6 apps on the device and under storage its saying that I only have 1.1gb free and 4.1 gb used. I looked under storage and there is nothing taking up that much space. If I install all my app that I like about 90, it then says I am low on space. I have installed the same apps on my phone and they take up less than 1gb. I don't know what is taking up so much space.
My other issue is when I did a backup through recovery (CWM) I can't find the folder its in. I have done 2 different backups and cant find either one. I've looked on the sd card (internal storage) and also on the ext sd in the CWM folder and its empty. When I was on stock, I also made a backup and I found it on the sd card in the CWM folder. I then moved this file to the ext card under CWM and that one is still there.. Ever since I did the backups on this carbonrom, I can't find the backup location. I tried going back into CWM and seeing if there was a settings option to designate where to put the backups but could not find a option for that. If anyone has any feedback on what is going on, it would be greatly appreciated. Thanks
