Help Case/Cover that works with grip sensor?
mayen
When I bought my Continuum, I also purchased a case/cover (not sure of the difference, sorry) to prevent scratches and fingerprints on the back and side of the phone. The case/cover was labeled for Samsung Contiuum and Galaxy S. However, I cannot use the grip censor with this case/cover! It's very frustrating.
I took the case/cover off to make sure that it wasn't the phone itself having issues. Without the case/cover, the grip sensor works 100% fine.
Do any Continuum owners have a case that works with the grip sensor? I'd really like to get something that protects my phone without sacrificing a great feature. Thanks.
PS: This is the cover I have. http://www.verizonwireless.com/b2c/...ryDetails&archetypeId=12445&accessoryId=46546
The most effective way to have the grip sensor work with a case would be to have holes on either side to allow you to touch the phone....
Get a cover at zagg.com. They're like a heavy duty full body sticker. I had one on my old phone and it was great. And it doesn't cover any buttons.
I hate when verizon has an accessory that doesn't really work the right way.
suggestion: squeeze harder
I just purchased a Continuum and I won't receive it until next week. I'm in the process of ordering a case and screen protector. Any suggestions?
PS: This is the cover I have. Set Your Location
I have a cover just like the one you purchased. What I did was I took a knife and cut out my own holes around the area where the grip sensors are located.
The holes obviously don't look like it was purchased that way. But it works. I'm able to have a case on my phone while still being able to use the ticker.
Could you possibly attach a photo of it? I'm going to cut holes in mine, but it'd be helpful to see how you did it!
Just purchased that phone and case. It's a Xentris for the Continuum snap on cover works great for the ticker at the bottom. I personally find the ticket a bit annoying but it's a new phone so that's to be expected. Hope this helps.
