Accessories Case for 2150
NightAngel79
Mandalorian
Administrator
So I JUST got a 2150. Am I to believe that Htcpedia (whatever its called) is the ONLY one who sells a case for 2150? Anyone get the hard shell one?
I see that htcpedia has an extended battery case for the 2150 mAh battery for the HTC Incredible. Is this the only options for now? Anyone purchased one can offer first hand experience? Losing the OB Commuter for the bigger battery option. Thanks.
I ordered one. I just got it in. It is the black silicone case. The silicone case is too loose with the cut to fit hole in the back. And the it looks like they just cut to fit a regular case. The job is pretty sloppy in my opinion. That is what I get for being cheap and not getting one modded from DrPheta. I should have just cut one myself, then I would only have myself to blame if it came out looking like poop. And it does look like poop.
AFAIK that's the only source unless you mod your own. I just cut a couple of slits in a Verizon hi gloss case so it stretches to cover the battery hump.
Not really a fan of the soft cases, was thinking of trying the hard shell htpedia one, figure if i'm gonna pay around that much money anyway then might as well get one designed for it.... meh.....
I know i can't stand using this without a case
I tend more toward the idea that a soft case that covers the back is better than a hard one that doesn't.
There's also the Seidio extended case, but they claim it only works with their extended battery. Seems like it should work with the 2150, but nobody has tried that I know of.
Was thinking about the seidio, there's is shaped a little differently. Plus i'm more worried about the edges and front of phone. I'm totally anal about that, I don't have a single scratch anywhere on my phone, lol
